Please help!!!!!!!!!!!!!!!!!!
Discussion in 'General Electronics Chat' started by Ryan Grosso, Jan 15, 2015.
  1. Ryan Grosso
    Jan 15, 2015
    I have an hdtv with component ports, av1 and av2 ports. and 3 hdmi ports. There is no audio out port. Which is my problem. i have a receiver that I am trying to hook up for surround sound but the receiver doesn't have an hdmi port. The receiver does have an optical port, but tv doesn't. What do I need?
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    You need help writing a better title for your post.
  3. kubeek
    Sep 20, 2005
    4,686
    805
    Dr.killjoy likes this.
  4. Ryan Grosso
    Jan 15, 2015
    It's not about the title, it's about my problem.
  5. MrChips
    Oct 2, 2009
    12,622
    3,451
    We frown on titles that do not give much information.
    Please think about it. How does your title help our readers?
    Just the opposite. A reader is less inclined to help someone who is thoughtless and selfish.
  6. MrChips
    Oct 2, 2009
    12,622
    3,451
    Well, you have a serious problem of communication.
  7. wayneh
    Sep 9, 2010
    12,362
    3,220
    That's very common, and it's a dead end. I don't think there is an easy solution. Your TV's HDMI ports are almost certainly inputs only.
    I believe it's a residual problem of content protection. They didn't want to allow a digital output of the protected content. Audio-out has become a sought-after feature on TVs, though, and I think it's much more common now.
  8. Dodgydave
    Jun 22, 2012
    5,130
    766
    if your receiver has audio input, then take the sound from the av outputs L+R pins 1,3, 4gnd.
  9. Externet
    Nov 29, 2005
    775
    57
    o_O No audio output port is not a problem. That is solved with a soldering iron, tapping from speakers or before volume control, rca jacks...
    Give me digital video output !!!! :mad: on ALL consumer TVs ! Protection...:rolleyes:
  10. crutschow
    Mar 14, 2008
    13,462
    3,353
    I think the best solution is what Externet proposed.
    I assume your signal source is over-the-air(?).
    A less desirable solution would be to use a Digital to Analog TV converter box designed for old analog TVs. Those usually have an audio output. But that means you would have to tune both your TV and the box to change a channel.
  11. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    If the title gave a clue to what the problem was - someone with the answer might bother to read it.
    djsfantasi likes this.
  12. Jim Reese
    Nov 5, 2014
    If it's an hdtv is there not an audio output? Could be a fiber optic out only. How about pictures?
    What make and model TV?
  13. Reloadron
    Jan 15, 2015
    1,038
    267
    OK depending on manufacturer:
    The above is just an example but as to the AV In / Out make sure you are connected to the AV Out on the set and a suitable Input on the amplifier. Generally as in the image Red is Right Audio, White is Left Audio and Yellow is Video. Some sets require going into their menu and setting up the outputs it can be as simple as On / Off for the used outputs. Make sure your amplifier has the correct source set for the audio input connectors you are using. Probably 95% of the time friends and neighbors call me with a problem like this it comes down to the setup and something not connected or setup correctly. The answers are generally found in the TV Set and Amplifier manuals. I would start there.
    Ron
  14. djsfantasi
    Apr 11, 2010
    2,899
    870
    Reloadron's picture provides a lot of information.
    Can you provide similar ones from your TV and Receiver, Ryan?
  15. Reloadron
    Jan 15, 2015
    1,038
    267
    Actually ripped off online. :)
    My wife was watching the morning news and enjoying her coffee so I thought better of moving the TV for a photo op session.
    Ron
  16. Dr.killjoy
    Apr 28, 2013
    1,204
    157
    Happy wifes makes for a happy life.. Lol
  17. ian field
    Oct 27, 2012
    4,447
    791
