Please Help with This Circuit
Discussion in 'General Electronics Chat' started by mrkabukiman, Dec 3, 2008.
  1. mrkabukiman
    Dec 3, 2008
    Hi, I am rather interested in this whole circuity business, and would love to make this fm transmitter :
    http://electronics-diy.com/BA1404_Stereo_FM_Transmitter.php
    The only issue is, and this makes me feel a little retarded, that I cant find where to hook up the negative power terminal. The bit in the upper right hand corner clearly labels the positive power input, but for the life of me I cant find where the negative input goes. I am rather new to this, and would appreciate any help.
  2. leftyretro
    Nov 25, 2008
    394
    The negative power terminal wires to the terminal just below the the one labeled positive power, labled GDN. The little arrow pointing down from that terminal means it connects to all the other down arrows throughout the diagram. That is known as circuit common, or sometime ground, and they show it that way to eliminate all those points having to be drawn together and making the drawing harder to read.
    Make sense?
  3. PRS
    Aug 24, 2008
    989
    35
    See that + in the upper left corner? Right below that is a hole. Hook your ground to that.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The BA1404 FM transmitter IC has not been made for many years and had poor performance. It was replaced by Rohm with much better ones. An Australian magazine made The Micromitter project that uses one of the newer ICs. The IC uses a frequency synthesizer with a quartz crystal and a phase-locked-loop.
  5. Farlander
    Oct 14, 2008
    158
    Could this newer fm transmitter IC switch a fet carrying about 100 amps? Over what frequency range?
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The FM transmitter has a sine-wave output from 88MHz to 108MHz.
    A FET can switch and make a square-waves but not at such a high frequency.
    What are you driving with 100A?
