please help with my crossroad traffic light project...
Discussion in 'Homework Help' started by D@rkL0rd, Jun 22, 2014.
  1. D@rkL0rd
    Jun 22, 2014
    25
    hey guys,i was working on my traffic light project and i created circuit using 555 timer(mono-stable mode) and ic 4017 but when i run the simulation in circuit wizard only first led's light up .i don't know why is this happening please help...
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Your circuit don't work because of your poor design. And you don't know how BJT work.
    Are you sure that you need this OR gates ? Why you don't use diode as a OR gates?
    Also why you connect all your LED's into BJT's emitter?
  3. djsfantasi
    Apr 11, 2010
    2,914
    881
    I am not a 555 expert (there are many on here!), but your wiring looks "funny". Take a look at the bistable multivibrator circuit in Bill Marsden's blog. Particularly in regards to your connections to pins 2 & 6. Also the connection to pin 3 looks odd and no connection to pin 7 is required.
    Please refer to the link to the blog above.
    Also, I agree with Jony130 observations about your BJT usage.
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Welcome to the forum!
    The mode should be astable (as in your sim schematic).
    I'm not familiar with Circuit Wizard, but the sim runs ok in LTspice.
    Are your logic and counter ICs configured for a 12V supply? (In LTspice they're configured for 5V by default).
  5. D@rkL0rd
    Jun 22, 2014
    25
    Sir can you please tell me how it should be .i admit i dont know much about BJT's .And according to my assignment project i have to use any one of the 7 logic gates...Thnx
  6. D@rkL0rd
    Jun 22, 2014
    25
    I am also not familiar with the circuit wizard but it it had all the ic's i needed so i used this one
  7. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Yes, but CW may expect you to use a 5V IC supply!
  8. D@rkL0rd
    Jun 22, 2014
    25
    no sir it does not solve the problem...
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
    Simply in CW you can change IC supply.
    Project--->Simulation--->Power supply
  10. D@rkL0rd
    Jun 22, 2014
    25
    while running simlulation after changing the power supply the y3 led just blew up...please explain how to avoid this...it said the reverse voltage distroyed it...please tell me how to avoid this...
  11. djsfantasi
    Apr 11, 2010
    2,914
    881
    1) how long do you want each pin to remain high? That is, what is the clock rate from the 555?
    2) Is your 555 circuit generating that rate? You can wire it's output to an LED for a quick check.
    3) Is the 4017 counting properly? If the clock rate is slow enough, you should be able to check with a DVM.
    4) independent of the 4017 and the OR gates, can your transistor drive one LED? Take a look at this article on this site's e-book on using an NPN BJT as a switch. Hint: You are missing resistors.
    Once these sub-circuits are known to be working, combine them.
    The secret in building/debugging is to break the problem down into simpler problems and make sure they are working. IMHO, I see you saying "I've got this big problem and don't know what to do!" Well, break it into smaller problems.
  12. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Try a diode in series with the transistor base.
  13. sheldons
    Oct 26, 2011
    616
    101
    The transistors are connected with no base resistors, leds to the transistor emitter not the collector and the 4017 has no reset on power on plus the 555 needs to be correctly wired
  14. JoeJester
    Apr 26, 2005
    3,403
    1,229
    You have a power source, a clock, a controller, and an LED driver. Work on one thing at a time till you get them as you want them.
    djsfantasi likes this.
  15. D@rkL0rd
    Jun 22, 2014
    25
    1-i want each pin to be high for 1 sec.
    2-no it is not generating that rate ...please help here...i am a newbie here...
    3-no the output is not given by the counter.
    4-i am still working on that ...can you recommend the resistor values for driving 4 led's
  16. D@rkL0rd
    Jun 22, 2014
    25
    i tried to build the oscillator but the pulse does not seem stable for 1 sec..please help me here...
  17. djsfantasi
    Apr 11, 2010
    2,914
    881
    I gave you a link that showed how to wire up the 555...
  18. D@rkL0rd
    Jun 22, 2014
    25
    Ya but whats the problem in this one...please help...and it was for bistable mode...i think we need a monosatable mode...
  19. djsfantasi
    Apr 11, 2010
    2,914
    881
    It's wired wrong...
    Let me clarify something. You want a circuit based on a 555 that will generate a pulse once every second? Why do you think you need a monostable circuit?
  20. D@rkL0rd
    Jun 22, 2014
    25
    so which one do you will be suitable here...
