So what ground connection do i use for the ground pin[21] on the ICL7117?Most importantly, the ground of this ICL7117 circuit should not be connected to the ground of LM35 circuit. InLo is connected to common and is at about 2.8V down from +5V. This is normally not a problem as ICL7117 meters are powered with battery, and normally uses a charge pump -V generator.
BTW, If you had already connected ICL7117 Gnd and external circuit Gnd (LM35), then common would have been shorted to ICL7117 Gnd, and I am not sure that the IC will survive this, more likely I am afraid it will not. Common is a reference voltage.
LM35 has three legs. Leg 1 Power, Leg 2 Analog Output, Leg 3 Ground. I think you are on the right track. You need to connect Leg 2 of LM35 to IN HI of the ADC, connect Leg 3 of LM35 to IN LO of ADC, connect IN LO to Ground (like it is shown with the doted line) because I think LM35 is the single ended input.Hi!
Unfortunately whilst integrating the temperature display circuit with another, something had gone wrong and I'm back to where i started!
The ADC is outputting a high at all outputs. After hours of not being able to solve the issue I disconnected the ADC and began connecting it again from the start. I've found another datasheet online from:
http://www.komponenten.es.aau.dk/fileadmin/komponenten/Data_Sheet/ADC_DAC/ICL7116_ICL7117.pdf
The circuit diagram is as follows:
where the dotted line connection between 32 and 30 IS made. The connection between 21 and 30 IS NOT made.
On this datasheet I've also found a way to test the ADC to see if it's functional (If pin 37 is sent a high all segments on display light up). I've performed this test and am confident that the chip is still operational.
However it still doesn't display anything; all outputs are at a high. If i give 37 a high to test; all segments light up. When I ground 37 all segments are off again.
I think the problem is occurring as I have no separate external digital and analog Grounds.
This is because the LM35 only outputs a high anologue signal which means i only have IN HI to the output of LM35 and no connection to IN LO (except what's represented above).
This is what I had mentioned, which would keep all the grounds together and keep Common, Pin 32, not connected to Ground. This allows internal reference to be used.BTW, did you try disconnecting common from InLo, and connect InLo to both the 7117 Ground and input LM35 grounds?
by Jerry Twomey
by Aaron Carman
by Aaron Carman
by Jake Hertz
