Please help with DOORBELL project
Discussion in 'The Projects Forum' started by Alichino, Feb 20, 2012.
  1. Alichino
    Feb 20, 2012
    7
    Let me say from the start I am an absolute beginner.
    I want to make a doorbell that after pressing a button plays a number of subsequent sounds in a melody. Namely - the beginning of Bach's toccata and fugue d-minor.
    What would I need to make such a circuit?
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    If it is a song then how realistic would u like to play it. Audio is atleast 16bit. Melody can be 4 or 8 bit.
    The higher the bit rate the realistic is the sound
    Second is the button wired or wireless.
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
  4. Alichino
    Feb 20, 2012
    7
    I want 9 sounds of varying frequency and length. You know, the opening of the toccata. I'm not sure about the bit rate... What is the difference? I would opt for the one easiest to make ;-)
    I'm thinking wired, but if wireless is not that much more difficult then perhaps wireless.
  5. R!f@@
    Apr 2, 2009
    8,785
    771
    How about buying a wireless one on ebay and modifying the ring tone Assy. I bet it is do-able
  6. Felo
    Member
    Feb 20, 2012
    91
    13
    I have once made a circuit based on a 16F628A wich produced sound output from its PWM, fairly easy to do if you just want to press button, then tune out. I would suggest going that road if you are comfortable with PIC's
    Good Luck
  7. MrChips
    Oct 2, 2009
    12,622
    3,451
  8. hwy101
    May 23, 2009
    91
    28
    I used one of these as a doorbell years ago, worked great.
  9. Alichino
    Feb 20, 2012
    7
    I've got an 8ohm loudspeaker now, it's not very good to be honest, it wails like a siren. But anyway, is there a relation between the emitted frequency of sound and RC?
  10. t06afre
    May 11, 2009
    5,939
    1,222
