Hi, I have a question. I have been doing a lot of reading here and other sites and I have learned quite a bit, but I am still not sure about what I need to do for my application. I am building a simple halloween prop and I want to use something like a wiper motor to rock it back and forth. I already made a 3d model including the motor and built a linkage system so the rotation of the motor would provide the back and forth motion I was looking for. I know I can throw on a speed controller and then control the speed. the problem I have is Now I also need to control the degree of back and forth motion too. I am not sure how to do this with a linkage mechanism. it seem like I would actually need to not use a mechanical linkage and just auto reverse the motor continuously. this also seems possible. however I want the degree of rotation to be adjustable at any given time. Example I want the motor to be turning 60 degrees back and forth then be able to adjust it to turn say 30 degrees or 90 or anywhere in between at say 10 degree increments. does this make since? I sometimes have a hard time explaining things. it does not need to be real strong or atleast i dont think so. if it can move 3 or so lbs in either direction that would be fine. speed I want to be able to control. it can have a slight pause if needed but less than a second pause would be ideal otherwise i think it is going to look funny. I am open to using a mechanical linkage system still, but i don't know how to do it without making the hole thing really complicated.
thanks
thanks
