I need to build a conversion circuit. It needs to convert a voltage ranging from (135VDC to 160VDC) to a current ranging from (16mA to 8mA).
The only way I can think of to do this is to first build a voltage regulator at about 130VDC then uses an op-amp to invert a current output. One of the problems that I have is that I want the keep the higher voltage source isolated from the op-amp and output voltage source.
When Input is 135VDC the output is 16mA and when Input rises to 160VDC output drops to 8mA.
Is there an easier way to do this?
