PLEASE HELP!! Wiring a 25 hp 3 phase ac motor with 12 leads
Discussion in 'General Electronics Chat' started by wallstreet1981, Nov 16, 2015.
  1. wallstreet1981
    Nov 16, 2015
    It's a 25 hp Hawker Siddeley 3 phase ac motor with 12 leads. I found the proper wiring diagram from a guy in Korea but the motor leads are labelled 6,6,7,7,8,8,T6,T6,T7,T7,T8 and T8.
    The like leads are twisted together at the end, so there's 6 pairs.
    Doesn't follow the typical 1-12 convention.
    Can anybody help????
    I can post pics if needed.
  2. tcmtech
    Nov 4, 2013
    2,118
    1,753
    On each matching pair there should be a second indicator on one label (line or dot over under or beside one number set on one lead) that designates which end of the winding it is.
    Once you have that you can relabel each winding end with the more standard code you are familiar with.
    Hypatia's Protege likes this.
  3. Dodgydave
    Jun 22, 2012
    5,161
    772
