Please help, Why is the led off
Discussion in 'Homework Help' started by sensor, Sep 8, 2009.
  1. sensor
    Sep 8, 2009
    18
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    There must be a voltage source at the input of the regulator.
    This must be at least 2 Volts higher than the output voltage.
    Greetings,
    Bertus
  3. JoeJester
    Apr 26, 2005
    3,394
    1,213
    What is the input voltage to your 7805 voltage regulator?
    You need to have a voltage source connected to the input of the regulator.
    Your resistor is very large ... at 20 mA, it would drop 30 volts. Your LED is probably 1.5 Vf @ 20 mA. With a 5 volt supply, you would need a much smaller resistor.
  4. sensor
    Sep 8, 2009
    18
    How did you calculate 30 volts?(V=IR)
  5. Mike2545
    Mar 26, 2009
    116
    Your resistor value is too big.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Ohm's law. E = IR , so .02(amps) X 1500(ohms) = 30(volts).
  7. sensor
    Sep 8, 2009
    18
    How can i know this(about a led)?
    What's 1.5vf?
  8. steinar96
    Apr 18, 2009
    239
    Leds are pretty standard. It's easy to google up drops for different colors of diodes. Vf means the forward voltage drop which is the voltage measured accross it when it is forward biased (LED is actually a diode). . 1.5Vf means that when conducting 1.5 Volts are dropped accross it.
  9. sensor
    Sep 8, 2009
    18
    But it was only 1K resistor.
    1k=1000(ohms) is it correct?
  10. steinar96
    Apr 18, 2009
    239
    sensor. You want 20mA trough your led correct ?
    The led will drop 1.5V. If you have a 5V supply it means you want the resistor to drop 3.5V accross it.
    Calculating (5V-1.5V) / 0.02A we get 175 ohms.
    So the resistor needs to be 175 ohms for this setup to work. With a 1k resistor the diode is deprived of current
  11. JoeJester
    Apr 26, 2005
    3,394
    1,213
    Your diagram showed a 1k5 .... that's 1.5k or 1500
  12. sensor
    Sep 8, 2009
    18
    Thank you for your information.
    I did not know that 1k5 means 1.5K(kiloohms).
  13. sensor
    Sep 8, 2009
    18
    http://img35.imageshack.us/i/35855855.png/
    You are right.
    But i can't find any resistor less than 1k in proteus/ISIS 7 pro.
    I got 0R1.
    What does it mean by 0R1?
    NB:This time the led is on.
  14. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    A resistor od 0R1 is a resistor of 0.1 Ohms.
    Can't you edit the properties of the resistors?
    I do not use the simulator but some have the option of a rightclick on the resistor,
    so a popup box shows up to edit the value.
    Here is a list of standard resistor values:
    http://www.educypedia.be/electronics/resistancevalues.htm
    These values can be muliplied by 0.01, 0.1, 1, 10, 100, 1K, 10K, 100K, 1M.
    More information on component coding can be found in the links of this page:
    http://www.educypedia.be/electronics/datacomponent.htm
    Greetings,
    Bertus
  15. sensor
    Sep 8, 2009
    18
    Thank you.
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
