please help why dose the code work with tmr0l but not tmr0h
Discussion in 'The Projects Forum' started by mhghost, May 17, 2013.
  1. mhghost
    May 16, 2013
    6
    hi i am trying to make a project and her is a small part of it
    here is the code
    Code ( (Unknown Language)):
    1.
    2. sbit LCD_RS at RD2_bit;
    3. sbit LCD_EN at RD3_bit;
    4. sbit LCD_D4 at RD4_bit;
    5. sbit LCD_D5 at RD5_bit;
    6. sbit LCD_D6 at RD6_bit;
    7. sbit LCD_D7 at RD7_bit;
    8.
    9. sbit LCD_RS_Direction at TRISD2_bit;
    10. sbit LCD_EN_Direction at TRISD3_bit;
    11. sbit LCD_D4_Direction at TRISD4_bit;
    12. sbit LCD_D5_Direction at TRISD5_bit;
    13. sbit LCD_D6_Direction at TRISD6_bit;
    14. sbit LCD_D7_Direction at TRISD7_bit;
    15.      char lcd[6];
    16.      unsigned long x ;
    17. void main() {
    18.
    19.    TRISA=1 ;
    20.    TRISd = 0;
    21.    PORTd= 0 ;
    22.
    23.    delay_ms(200);
    24.     LCD_Init();
    25.     LCD_Out(1, 1, "Speed In RPM:");
    26.     TMR0H = TMR0L = 0;
    27.
    28.      T0CON=96;
    29.
    30.  delay_ms(2000);
    31.
    32.
    33.
    34.   while(1) { x = (TMR0H<<8 ) + TMR0l;
    35.
    36.       inttostr (x,lcd);
    37.
    38.       lcd_out(2,1,lcd);
    39.       delay_ms (2000);
    40.
    41.
    42.
    43.    }
    44.
    45.  }
    46.
    but when i use tmr0h my nothing happens i am useing a 4 MHz and isis simulator and in anther part of it i get this error
    "Simulation is not running in real time due to excessive CPU load".
  2. mhghost
    May 16, 2013
    6
    oh sorry wrong code here is the one with the problem
    1.
    2. sbit LCD_RS at RB4_bit;
    3. sbit LCD_EN at RB5_bit;
    4. sbit LCD_D4 at RB0_bit;
    5. sbit LCD_D5 at RB1_bit;
    6. sbit LCD_D6 at RB2_bit;
    7. sbit LCD_D7 at RB3_bit;
    8.
    9. sbit LCD_RS_Direction at TRISB4_bit;
    10. sbit LCD_EN_Direction at TRISB5_bit;
    11. sbit LCD_D4_Direction at TRISB0_bit;
    12. sbit LCD_D5_Direction at TRISB1_bit;
    13. sbit LCD_D6_Direction at TRISB2_bit;
    14. sbit LCD_D7_Direction at TRISB3_bit;
    15.
    16.   char txt2[10];
    17.   char txt1[10];
    18.   int  x=0;
    19.   int y=0;
    20.   int q =0;
    21.    void main(){
    22.    TRISB =0;
    23.
    24.     Lcd_Init();
    25.     delay_ms(2000);
    26.     lcd_cmd( _LCD_CURSOR_OFF);
    27.     T0CON =0b10001111;
    28.     lcd_out (1,1,"time is ");
    29.     lcd_out(2,1,"m=0");
    30.     lcd_out(2,9,"s=0");
    31.   while(1){
    32.
    33.
    34.
    35.     //while(tmr0h < 0b00000001){}
    36.
    37.
    38.     while(tmr0l < 0b11111111){}
    39.     lcd_out (1,1,"time is ");
    40.     x++;
    41.     T0CON =0b00001111;
    42.
    43.     tmr0h=0;
    44.     tmr0l=0;
    45.     T0CON =0b10001111;
    46.
    47.   if(x==38){x=0;q++;}
    48.   if(q==60){q=0;y++;}
    49.
    50.   inttostr(q,txt1);
    51.   inttostr(y,txt2);
    52.   ltrim(txt1);
    53.   ltrim(txt2);
    54.   lcd_out(2,1,"m=");
    55.   lcd_out_cp(txt2);
    56.   lcd_out(2,9,"s=");
    57.   if(q<10){ lcd_out_cp("0");}
    58.   lcd_out_cp(txt1);
    59.
    60.
    61. }   }
    62.
  3. Dodgydave
    Jun 22, 2012
    5,166
    775
    Which Pic are you using?
  4. mhghost
    May 16, 2013
    6
    i am using 18f452
    and the code works with a delay of 5 sec per mint i don't know why i tried to change the tmr0l limit but it dose not change any thing and when i try to use timer high the isis frezess
  5. tshuck
    Oct 18, 2012
    3,531
    675
    from page 107 in the datasheet:
    You have to read the low bye in order for the high byte buffer to be loaded with the current value.
