Please Help Verify My PCB
Discussion in 'The Projects Forum' started by Colossus, Aug 17, 2009.
  1. Colossus
    Aug 12, 2009
    I designed my circuit using the ExpressPCB software. The dimensions are 3.8" x 2.5". The module transfers audio frequencies into LED light pulses. The sound and signal input is supplied by a male to male audio cable. This cable can be hooked up to you computer's sound card.
    Basically it is an imitation of the Audiostrobe glasses: which transfers audio waves (music) into light to help you relax. They cost about $150 so I thought it would be fun to make them instead.
    IC1 - LM567C tone decoder
    IC2 - L7805T voltage regulator
    R1 - 470 Ohm
    R2 - 47 Ohm
    R3 - 47 Ohm
    C1 - 0.1uf
    C2 - 0.005uf
    C3 - 0.02uf
    C4 - 0.01uf
    C5 - 1uf
    C6 - 100uf
    C7 - 10uf
    All three jacks are standard 3.5 mm audio jacks.
    The top jack (Output) is connected to the LEDs. I am using the LED leads to connect to each other. Using a wire to connect the cathodes of the right side to the anodes of the left.
    The middle jack (Input) is male to male audio cable running to a PC sound card or MP3 player.
    The bottom jack (Phone) is where you plug in your headphone to listen to the music.
    I also decided to add a SPDT switch unit which can switch between two outputs. In your opinion what is the best option for configuring the LEDs? How many can I use?
    Also, do you think i should integrate R2 near the LEDs instead of on the board?
