please help urgently
Discussion in 'The Projects Forum' started by Sofo Razak, Jun 2, 2008.
  1. Sofo Razak
    Jun 2, 2008
    please i am doing a project work on the applications of boolean algebra and will like help as to how to construct a washing machine controller with with a counter and a decoder, Or any simple application of boolean algebra.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A digital clock might be easier than the washing machine controller.
  3. mik3
    Feb 4, 2008
    4,846
    63
    A circuit which counts objects passing a point is an easy project to do. Use a sensor to detect the object (laser with LDR, infrared sensor or whatever you can find) and a counter to count the pulses send by the sensor and thus the number of objects. Then use a seven segment display driver to show the number of objects on a seven segment display.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Something I've been meaning to do for winding coils, a simple counter connected to the wire winder to count turns of wire. This would be good for custom transformers and Tesla coils.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Bill, somewhere I read about a guy who converted one of those cheap pedometers for use as a turn counter on his coil winder.
    But if you wanted a somewhat faster version:
    http://www.skycraftsurplus.com/index.asp?PageAction=VIEWPROD&ProdID=649
    I just used a UGN3130 Hall-effect sensor and some CMOS IC's hooked up to some 7-segment LED's.
