Please help to identify component please
Discussion in 'General Electronics Chat' started by rastaman46, Feb 29, 2016.
  1. rastaman46
    Nov 17, 2011
    69
    Hi all again!!!
    Can some one help me to identify this component please?
    It have code on it
    SMS T23P
    R022 5%
    What is it resitor cap and such?
    And thanks every one for any replys
    Regards
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    It's a 0.022 Ohm resistor.
    rastaman46 likes this.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,691
    1,297
    For low value resistors, R is used as the decimal point because a real decimal point is too easy to miss.
    ak
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    Did it really require a 2.8 MB file to show the needed detail?
    Consider:
    Seems to do the job in well under 100 kB.
    Notice the size of the component compared to the capacitors and the IC below it. That's an indication that it is intended to carry a fair amount of current. It's probably being used as a current sense resistor.
  5. rastaman46
    Nov 17, 2011
    69
    Thanks all for replies.
    Replaced this part but still no joy .
    Further investigation in the circuit I did find the one more burnt part
    can any one help me to identify it please whats is it??
    Thanks again all
    Regards
  6. Dodgydave
    Jun 22, 2012
    5,150
    769
    Looks likes a resistor burned out, possibly in series with the transistor, no way to tell its value unless you remove it and measure it, or look at the coloured rings.
  7. rastaman46
    Nov 17, 2011
    69
    Thanks for reply
    So the value should be the same even if it burnt ??
    Cant see any colour codes coz all burnt
    Regards
  8. Dodgydave
    Jun 22, 2012
    5,150
    769
    The value will have probably increased in value or gone open circuit, unless there is another resistor on the pcb thats the same to compare it with, then your doomed...
  9. rastaman46
    Nov 17, 2011
    69
    Thanks for reply again
    No I cant compare with nothing its only one that big
    So they can increase value or go short?
    Is it worth to get few different values and transistor aswell?
    Regards
