Could you kindly look at the attachment with the questions which I just made in powerpoint to illustrate my question? Again this is an important question and there are good reasons for me asking it. I've been very curious about the voltage/current of the master power strip plug vs plugs that go into the power strip (from various devices). All three questions assumes the power strip is turned on, not off. It is not a surge protector.
My hypothesis is :
In the scenerio of question 1, the shock would be the same from A or B?
In the scenerio of Question #2 the voltage/current is higher for A (leading to greater shock) vs B and C, because A should have double the voltage/current to provide evenly between B and C? Because B and C are drawing power? This is assuming B and C are drawing power to similar machines, for example one vacuum cleaner each, because i know different appliances use different amounts of power.
In the scenerio of Question #3, my hypothesis is that A will lead to a greater shock, approximately double that of touching B?
I do not intend of course, to try anything to test this out nor do I have any intention of hurting anyone or myself. I am literally asking a question that is eating at my curiosity due to my OCD. Please answer specifically in non-scientific terms and I appreciate your help! Previously some geniuses have helped me answer my
questions and I really really appreciate it and am grateful. So Thank you in advance.
LAST QUESTION #4) Imagine the power strip is on an both plugs B and C are drawing power to their respective machines which are On. what happens if a person touches the prongs of B AND C (four in total) in one hand? How will the electrical path look like? will it still be two separate electrical paths, one among B (from first prong of B to second Prong) and one among C (from first prong of C to second prong)? or will they connect somehow? I'm not looking for answers of person will die etc etc, I'm asking the effect it will have as to the electrical path through the hand.
My hypothesis is :
