Please help - Series Parrallel Circuit
Discussion in 'General Electronics Chat' started by shebby, May 22, 2013.
  1. shebby
    May 21, 2013
    I am a high school student struggling with series parallel circuits please help with this question and explain how to break down. I will try my best to show problem
    Code ( (Unknown Language)):
    1.
    2. [FONT=Calibri][SIZE=3] [SIZE=1]------------------------------------ [SIZE=3]v[/SIZE]------------------[/SIZE][SIZE=1]3o 0hm-----------------------------------------------------------[/SIZE]v[/SIZE][/FONT]
    3. [FONT=Calibri][SIZE=3]                               [SIZE=1]10 ohm[/SIZE]                                                    [/SIZE][SIZE=1]1[/SIZE][SIZE=1]0 watt 120 volt lamp[/SIZE][/FONT]
    4. [FONT=Calibri][SIZE=3]                                [SIZE=1]10 ohm[/SIZE]                                                              v[/SIZE][/FONT]
    5. [FONT=Calibri][SIZE=3]   ---------------------------------------------------------------------- <[/SIZE][/FONT]
    6. [FONT=Calibri][SIZE=3] [SIZE=2]
    7. [/SIZE][/SIZE][/FONT]
    sorry bad diagram but cant copy paste. this is a circuit the v indicates arrows continuing the circuit. 1 branch has 2 10 ohm resistors. the other main circuit has a 30 ohm resistor and a 10 watt 120volt lamp. Please help answer. im pretty sure the formula is 1 over, 1 over R1 + 1 over R2 + 1 over R3 but im lost for some reason.
    Question.
    When current is flowing through the 10-ohm resistors, the voltmeter reading will be:(since its hard to show the volt meter is placed across the bottom 10 ohm resistor).
  2. shebby
    May 21, 2013
    thw 10 watt 120 volt lamp should be in the rear between arrows. this circuit is 120 volts
  3. shebby
    May 21, 2013
    the 10 watt 120 volt lamp should be in rear of circuit between arrows, circuit is 120 volts
  4. davebee
    Oct 22, 2008
    539
    46
    If I could understand the circuit I would try to help but the description of the circuit is not clear enough and the picture is too messed up.
