Please help! Op Amp question
Discussion in 'Homework Help' started by dacrazyazn, Mar 30, 2009.
  1. dacrazyazn
    Mar 30, 2009
    22
    hey guys, this is my first post here and i really appreciate the time you put out to help me.. heres the problem.
    "the OpAmp differentiator, with R=10kΩ and C=100pF has the input Vs(t)=2[sin(ωt)]u(t)V. Determine the frequency at which the OpAmp saturates at +15v or -15v.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Have you made an attempt at a solution? If so please provide a copy of your work so far.
  3. dacrazyazn
    Mar 30, 2009
    22
    i have tried to get it started... so far i got.
    KCL around the neg end of the OpAmp (node A).
    (the lower left hand side resistor, i called R1 and the other one i called R2)
    i2-iC-i1=iN (i2 correspond with R2 same with 1 and C)
    i2=(Vo-Va)/R2
    iC=C*d(Va)/dt
    i1=Va/R1
    now i thought since the opamp needs to be ideal*?* i set iN=0 as well as Va=0
    This brought me to the problem. because if Va equals to zero, then i would have zero for i1 and iC.
    i dont know for sure if i am going about this correctly, i was trying to follow an example from the book and modify the work to fit this solution. Please help...
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    In fact the Op-Amp configuration requires the voltage Va(t) at node A to equal Vs(t) - rather than zero as you have suggested. Assuming the current into Op-Amp at node A is zero is fine.
    You should be able to solve your equations given these conditions.
  5. dacrazyazn
    Mar 30, 2009
    22
    alright so i tried to solve it completely... and i got.
    Va(t)=Vs(t)
    Vs=2sin(ωt)u(t)V
    -Vs/R1 + (Vo-Vs)/R2 - C*d(Vs)/dt = 0
    (-2Vs + Vo)/R - C*d(Vs)/dt = 0 (since R1 and R2 are the same)
    ∫(-2Vs + Vo)/R*dt=∫C*d(Vs) (separated the two and multiplied by dt)
    Vo/R*t - 4/R∫sin(ωt)*dt=CVs
    Vo/R*t - (4/ωR)*cos(ωt)=2Csin(ωt)
    and im stuck here. can someone also explained what the u(t) in Vs is for? Thanks!
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    You should be able to go from here ...
  7. Ron H
    Apr 14, 2005
    7,050
    657
    I Got the answer by using the gain equation:
    Av=Zf/Zs + 1
    I plugged my answer for ω into your equation for Vo and got 15V peak, verifying both approaches.
  8. dacrazyazn
    Mar 30, 2009
    22
    Thank you soo much guys! i found my problem... i was looking at the WRONG DIAGRAM for the WRONG PROBLEM in the book. >.< ive done this a lot of times. but def it was outside of what we were learning. Thank you to Ron and T_N_K you guys are awesome. this is a great community btw! i've gotten so much just reading the "textbook" on this site! Thanks again!
