Every time I build an audio project I get an electric noise or a long beep on the audio output like the headphone out. This time Im working with an MP3 player that requires a 100uf capacitor in series with the line out. The noise is annoying?
Whats the problem? Grounding? Need to add extra components?
This is the mp3 im using
http://www.elechouse.com/elechouse/images/product/USB-SD MP3 Modules/WT9501M03.pdf
The circuit is on the pdf file at the bottom.
The noise is a noise! Like a long beep
Thanks!
Thanks!
