Please! Help needed with diode and mosfet selection.
Discussion in 'The Projects Forum' started by 1213brett, Feb 1, 2015.
  1. 1213brett
    Feb 1, 2015
    13
    I am trying to not only build but understand how this project works. Its a sentry gun. I am new to electronics and when I built it my diode burnt up! I used a 1n4004 diode. And a 6v airsoft gun at least one that takes 4 AA's battery's. At first the gun made a noise and did not fire. I think it's not getting enough current. I went into the program and put the gun on full auto and it still just made a noise but a continuous one. Then I substituted the 4 AA's for a 6V 3700 mAh battery. The gun still did not fire then the diode burnt up . This was probably a dumb thing to do but I'm new to this sort of thing. even before I switched battery's It smelt like something may be burning. Obvasly I'm not shore but I think the mosfet is wrong too because like I said the gun did not fire it just made a noise for a second. I have the lights, switches and servos all working. Its just the gun firing that's giving me troubles. Thank you for any help. Hear is the schematic. Schematic_ArduinoBare.png
  2. #12
    Nov 30, 2010
    16,671
    7,314
    1) There is no power supply to U1
    2) That mosfet needs 6 volts to turn on well.
    You need a, "logic level" mosfet and enough volts to turn it on.
  3. Evil Lurker
    Member
    Aug 25, 2011
    117
    24
    Second the motion on the logic level mosfet. I'd select one with a lower RDSOn, lower reverse blocking voltage, and higher amperage. And I would ditch R2 in favor of a gate current limiting resistor as Arduino pins can actively source and sink current... the deal is without a resistor you risk smoking your microcontroller's drive pin from over current when switching on/off a FET' thanks to their gate charge capacitance, or at least that is the way I understand it. Might want to go with a 1.5 to 3 amp diode in either fast or ultrafast recovery versions.
  4. 1213brett
    Feb 1, 2015
    13
    Please be specific with components would the fqn1n50c that #12 suggested work for the mosfet?
  5. #12
    Nov 30, 2010
    16,671
    7,314
    #12 did not suggest the mosfet you already have. He merely provided the datasheet so others could know what you're working with.
    If you said how much current the motor uses, we could make a guess about a replacement part.
    Perhaps one of these:
    http://www.mouser.com/Semiconductor...w7404Z1yw729iZ1yw6zntZ1z0y3zrZ1yw8qn6Z1yw8pjm
  6. 1213brett
    Feb 1, 2015
    13
  7. #12
    Nov 30, 2010
    16,671
    7,314
  8. 1213brett
    Feb 1, 2015
    13
    If I change q1 to Mouser part 844-IRL530PBF and d2 to 583-RL852-B do I need to change r2? If so could you please help me choose a new one?
  9. #12
    Nov 30, 2010
    16,671
    7,314
    Change R2 to not existing and add a resistor in series with the gate to avoid burning the processor. See post #3
  10. 1213brett
    Feb 1, 2015
    13
    How large a resistor should I put in series with the gate?
  11. #12
    Nov 30, 2010
    16,671
    7,314
    I don't know. I don't do Arduinos. Look on the spec sheet and find out how much current it can supply then put a limiting resistor in based on Ohm's Law.
    I=E/R
    Current available = voltage supply divided by the resistance you install.
