Please help - Need a Switch
Discussion in 'General Electronics Chat' started by jim6960, Dec 11, 2013.
  1. jim6960
    Dec 11, 2013
    I need to no what a switch would be called that is as described:
    "I need a switch that opens and closes a circuit when depressed down. Note : it can not do this like a normal limit switch by being pushed and released back up. It needs to signal a timer to start every time it time it is pushed then just reset when it is released"
    My timer needs a trigger powered for a split second to restart it.
    Any help would be appreciated .... Thank You
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    Can you post your timer circuit?
    Ken
  3. mcgyvr
    Oct 15, 2009
    4,787
    974
    Through the ramblings and mistake laden question I think what you are asking for is a "momentary" switch with either debouncing or delay on break timer functionality..
  4. inwo
    Nov 7, 2013
    2,435
    315
    I don't know of a switch like that.
    It takes a timer circuit called a one-shot.
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    Looks like the OP wants:
    Pushing and holding the switch button generates a brief "pulse" that starts the timer.
    Releasing the switch button generates something that resets the timer.
    I have no ideas without details...pulse length?, polarity?, voltage?, load?
    Ken
  6. inwo
    Nov 7, 2013
    2,435
    315
    Not my understanding. Could be wrong.
    I think OP wants a one shot pulse that is not lengthened by holding button or releasing.
  7. inwo
    Nov 7, 2013
    2,435
    315
    How about a differentiated pulse?
  8. jim6960
    Dec 11, 2013
    yes, I was wondering if there was a switch that would send a brief 1 or 2 second positive signal and I am using a 12v circuit.
    "A one shot 12v pulse that is not lengthened by holding button or releasing"
    I want to trigger a 6030 Altronix timer. I'm about to make a switch that will do what I need.
  9. inwo
    Nov 7, 2013
    2,435
    315
    I'll see if I can find that timer.
  10. inwo
    Nov 7, 2013
    2,435
    315
  11. inwo
    Nov 7, 2013
    2,435
    315
    If it's ~24vdc, try a 2.2uf capacitor in series with the switch. From + to trigger.
    That will differentiate the signal from the switch into a single pulse.
    I have no idea of the input impedance of the trigger, but it's worth a shot.
  12. KMoffett
    Dec 19, 2007
    2,584
    234
    Looks like BELL OUTPUT is the source of power to the board, so the trigger is pulled-up to the + voltage from the BELL OUTPUT, thru a dry contact switch.
    Ken
