some one give me a circuit.... that convert a 12 volts AC to 12 DC,,,,
Thread Starter transistor_circuit Joined Mar 9, 2009 4 Mar 9, 2009 #1 some one give me a circuit.... that convert a 12 volts AC to 12 DC,,,,
Audioguru Joined Dec 20, 2007 11,248 Mar 9, 2009 #2 Use a full-wave rectifier bridge then the voltage pulses will be +15V. Smooth and filter the pulses with a capacitor that is calculated for the current. Then use a 12V voltage regulator IC for a current of up to 1A. You forgot to say how much DC current you want.
Thread Starter transistor_circuit Joined Mar 9, 2009 4 Mar 9, 2009 #3 can you give a circuit.....bro???
beenthere Joined Apr 20, 2004 15,819 Mar 9, 2009 #4 Let's start you off with out Ebook on rectifiers. Remember that this is supposed to be your homework - do make some effort.
