Please help me with checking the busy flag of a lcd in 4 bit mode
Discussion in 'Embedded Systems and Microcontrollers' started by aakashjsr, Apr 16, 2014.
  1. aakashjsr
    Apr 16, 2014
    I am able to execute commands on my lcd when I use delay instead of checking the busy flag but when I check the busy flag,it appears as if an infinite loop has started.Here's the connections for my 4 bit Lcd with the AVR Atmega 16.Thanks a lot in advance :)
    Code ( (Unknown Language)):
    1.
    2. ************************************************** ***************************
    3. PB0-> RS ; PB1->ENABLE ; PB2->R/W ; PB3->NOT CONNECTED
    4. PB4-PB7----->DB4-DB7
    5.
    6. ************************************************** *************************** Code:
    7. ************************************************** ***************************
    8.
    9. #define data PORTB
    10. #define e PB1
    11. #define rs PB0
    12. #define rw PB2
    13.
    14. void lcd_ready() //checks for busy flag
    15. {
    16.
    17. DDRB&=0b00001111; //data lines as read
    18. int flag=0;
    19.
    20. cbi(PORTB,rs);
    21. sbi(PORTB,rw);
    22.
    23. do
    24. {
    25. pos_pulse();
    26. _delay_us(10);
    27. flag=PINB;
    28. flag=(flag&0x80); //to store the value of busy flag
    29. pos_pulse(); //discard lower nibble
    30. _delay_us(10);
    31. }while(flag);
    32. DDRB=0xff; //resetting data lines as output
    33. }
    34.
    35. void pos_pulse()
    36. {
    37. cbi(PORTB,e); // eable=0
    38. _delay_us(2);
    39. sbi(PORTB,e) ; // eable=1
    40. _delay_us(2);
    41. }
    42.
    43. void neg_pulse()
    44. {
    45. sbi(PORTB,e); // eable=1
    46. _delay_us(2);
    47. cbi(PORTB,e) ; // eable=0
    48. _delay_us(2);
    49. }
    50.
    51. void command(int a) // to receive and send command to LCD
    52. {
    53.
    54. //higher nibble
    55.
    56. lcd_ready();
    57.
    58. data=(a&0xf0);
    59. cbi(PORTB,rs);
    60. cbi(PORTB,rw);
    61. neg_pulse();
    62.
    63. //Lower Nibble
    64.
    65. lcd_ready();
    66.
    67. data=((a<<4)&0xf0);
    68. cbi(PORTB,rs);
    69. cbi(PORTB,rw);
    70. neg_pulse();
    71. }
    72.
    73.
    74.
    75. void value(int a) //To send Data to the Lcd
    76. {
    77.
    78. //higher nibble
    79.
    80. lcd_ready();
    81.
    82. data=(a&0xf0);
    83. sbi(PORTB,rs);
    84. cbi(PORTB,rw);
    85. neg_pulse();
    86.
    87. //Lower Nibble
    88.
    89. lcd_ready();
    90.
    91. data=((a<<4)&0xf0);
    92. sbi(PORTB,rs);
    93. cbi(PORTB,rw);
    94. neg_pulse();
    95.
    96.
    97. }
    98.
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    When posting code please use code tags:
    [code=rich]
    Your code goes here
    [/code]
    djsfantasi likes this.
  3. ErnieM
    Apr 24, 2011
    7,434
    1,625
    The statement:
    while(flag);
    has no ability to refresh the value of flag once set in a pervious statement.
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I think you missed the
    do {
    statement before it Ernie.
  5. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Ah, so I did.
    Never mind.
  6. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Does the Atmega require the direction of port pins to be either in or out?
    And what is that PINB for?
