please help me to solve the poblem of bridge rectifier
Discussion in 'Homework Help' started by jeevanpatil, Sep 4, 2013.
  1. jeevanpatil
    Sep 4, 2013
    i give 110V Dc to birdge through single pole MCB & output site of bridge i connect load.
    i observe following points
    1. when MCB is OFF I SEE 220V DC instead of 110V DC.
    2. when MCB is ON I see 110V DC.
    SO PLEASE TELL ME WHY THIS HAPPEN & HOW???????????????
  2. Sensacell
    Jun 19, 2012
    1,184
    277
    Please post your schematic, what is an 'mcb'?
  3. Ramussons
    May 3, 2013
    562
    92
    Main Circuit Breaker
    Ramesh
  4. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    I believe Miniature Circuit Breaker?
    I presume the MCB is between AC and the bridge? Is the load still connected when you get the 220vdc?
    Is any point from the secondary on at earth ground?
    Max.
  5. JoeJester
    Apr 26, 2005
    3,403
    1,230
    Post the schematic of your circuit and indicate where you are taking these measurements.
    Why did you choose to input 110V DC into a diode bridge?
  6. shortbus
    Sep 30, 2009
    4,098
    1,697
    To get to the other side.:p
