please help me to design counter
Discussion in 'Homework Help' started by ahmedalsh40, Apr 14, 2011.
  1. ahmedalsh40
    Dec 20, 2009
    14
    i went to design counter to count two numbers only (0 and 5) using flip-flop
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    What exactly do you mean count only 0 and 5?
    Do you want a circuit whose output will be the alternating sequence of 0 and 5?
    If so, you can just make a counter that will count from 0 to 1. You can use any single Flip Flop do to that.
    Then, take that as an input and form 4 different outputs that will produce either 0 or 5.
    Is that clear?
  4. ahmedalsh40
    Dec 20, 2009
    14
    yes i need to count two numbers only 0 and 5
    first signal show 0 second signal show number 5 and show zero and so
