The circuit below is for a solar panel charge controller. It monitors the battery voltage and once the battery is fully charged, a relay activates a dummy load to drain the battery down to a safe level.
The battery status LED's are working correctly and everything seems great except that the relay is not activating. Only the red LED is being lit. When the red LED is lit, the relay should activate, kicking over power to the dummy load.
Could someone suggest to me why the relay is not activating?? Any help is MUCH appreciated!!!
