Dammit. I read 'AA' not 'AAA'. Here's the datasheet:If you could make room for AA alkalines, that would more than double the life over AAAs.
http://data.energizer.com/PDFs/E92.pdf
Expect less than 1/2 hour of operation.
How long will it last? That's hard to say without more info on the LED. What kind of case is it in? How much heat can it dissipate? It might make a real kick stuff flash light before the batteries run down. I have flashlights that are just batteries and LEDs, no resistor. And I replace LEDs about once a year, maybe 100 hours of operation a minute at a time.Hi all I'm running a High power LED but having lots of problems. the specs are:-
Power Dissipation: 10W
Chip: Bridgelux
Life: 50,000h
Forward Voltage: 2.0-3.6V
Forward Current: 700mA
I'm powering this with 4 x AAA's
I only have 2 questions.
1) how long will the LED last before it burns out if i just carry on running it straight of the 6V (4 x AAA's) this doesn't have to be exact just a rough idea.
2) what resistor do i need to run this and still get the max light out of the LED
i'm based in wakefield town center - wf1 3rqhi Ben,
What is your location, so that we can suggest suppliers.?
E
What is the current drawn from the 6V Supply ?i'm testing the led connected to the 6v power supply now and it's working perfectly and been going over 2hrs so far so good sign or a worst case situation lol
Many cheap flashlights rely on the cells internal resistance to limit the current - it doesn't do the LED any good. Trying that with 4 cell isn't advisable!Hi all I'm running a High power LED but having lots of problems. the specs are:-
Chip: Bridgelux
Life: 50,000h
thank you for the help on this. I'm still testing the led but so far it's now run for 5Hrs and 48 mins the led is 100% A ok and the power has been constant and the LED hasn't dimmed or faulted in any way . it's extra good cause i'm running this on the cheapest batteries i could get from the pound shop so i'm very impressed. I admit the life span of the LED will drop but i'm confidant with the results and output so far.Dammit. I read 'AA' not 'AAA'. Here's the datasheet:
