Please help me repair power supply
Discussion in 'General Electronics Chat' started by nozit7022, Nov 8, 2015.
  1. nozit7022
    Aug 2, 2015
    Hi, good day. I'am electrician by profession. I would like to explore on the electronic side. I'm trying to repair the power supply but i'am stuck. There is no output voltage. I check on the bridge diode and there is output until in the primary side of the transformer and no on the secondary. Attached the pics of power supply. I hope you have time to help me. Thanks and GOD BLESS
  2. bwilliams60
    Nov 18, 2012
    734
    94
    What is the voltage (DC) across the large cap? What is the voltage coming in and the voltage on the primary side of the transformer?
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    nozit7022 likes this.
  4. Dodgydave
    Jun 22, 2012
    5,141
    767
    What you have there is a switchmode psu, the Top227 is an ic, and if its blown up it wont work, you need to measure the voltage on the chip.
    Hypatia's Protege likes this.
  5. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,842
    1,309
    Please be advised that the pictured PSU is an SMPS -- Your DMM/VOM may not be responsive or accurate at the (switching) frequencies/waveforms involved... --- You are best advised to focus upon DC measurements (electrolytic and other high-value capacitors being convenient test points)...
    Best regards and good luck!:)
    HP
  6. ian field
    Oct 27, 2012
    4,447
    791
    I'd advise against poking about with DMM prods - those Power Integrations chips can be a bit temperamental. They have a bit of a tendency to blow a crater in the plastic encapsulation when they go bang.
    First I'd test/replace all/any small electrolytics as routine maintenance.
    Very often a shorted secondary side rectifier shuts the PSU down, but I'd examine any power resistor between the chip and the negative of the reservoir electrolytic. Sometimes that blows open before the chip explodes.
    There's usually a high resistance start up resistor that can go high or open.
  7. #12
    Nov 30, 2010
    16,665
    7,313
    That yellow transformer looks burnt on its bobbin, but the photo is rather poor quality. I can't be sure.
  8. ian field
    Oct 27, 2012
    4,447
    791
    Those transformers are vacuum impregnated with varnish - then baked.
  9. hp1729
    Nov 23, 2015
    2,084
    232
    Attached is a data sheet for the TOP227. The schematic on it may be similar to your power supply.
  10. MikeML
    Oct 2, 2009
    5,450
    1,066
    SMPS's are a really bad circuit to learn on... A bunch of ways to kill yourself or your test equipment. If you insist on poking around in it, get yourself an isolation transformer, like this.
