please help me in this question on network ?
Discussion in 'General Electronics Chat' started by munna007, Jun 29, 2011.
  1. munna007
    Thread Starter Active Member
    Jul 23, 2008
    51
    Hello friends....in this questions the answer is (b) option.....this is from indian engg. services exam.
    if we apply mesh in loop which i have shown , then we find that
    I = (10 - 5 )/10 = 0.5 amp
    V=10 - 6 I = 7 volt (right acc. to answer keys)
    and Rth = 2.4 ohm (i have calculated Rth)
    but if we apply Nodal analysis where V is marked then
    acc to that
    (V-10)/6=(V-5)/4
    V= -5
    so we see that both results r not equal....but in answer keys 7 volt is given....
    plz tell me what is the problem in second method of nodal analysis.? is this wrong ?
  2. The Electrician
    Oct 9, 2007
    2,301
    338
    There are two currents entering the node marked V; their sum must be zero. You have set them equal rather than setting one equal to the negative of the other.
    Let your equation be (V-10)/6 = -(V-5)/4 and you will get V = 7.
  3. munna007
    Jul 23, 2008
    51
    thanku so much sir....i understood my mistake....:)
