I can use that too LOL C, asm, jalv2, pascal,
Did you look at the video I posted I ran the test in a loop but it worked out of the box when i realized I had Uart backward
I had rx to rx LOL
Thats some nice code you got going there. Here my idea let's test 14 pin chips only and get that to work for basically 7400 to 7436 I think that's right.
This is what I came up with 7 and 14 are power only pins so you would want them limited to a safe level. Resistor on them to keep it at less then 8 mA I tested at 5 mA all was good.
I then limited output and input to a max of .5 mA , reason I picked this value is most of these chips can only put out .8 mA
Looked like a nice limit to me.
Now if you look as the pinout link I posted you will see that this range of chips could be tested with just three pins
to give what type of gate it is after you find a match you test the whole chip.
I'll post you a pin sample for the 74ls11
I had rx to rx LOL
