please help me for midterm ON GRADE 11 boolean algebra
Discussion in 'Homework Help' started by joker_tony, May 28, 2008.
  1. joker_tony
    May 18, 2008
    i really need someone to me verify my answer. i will be having my exam next week and iam stuck :(. please iam really stuck on some of this question.
    ' this is not
    '' this is not, not
    1. F = B.(A''. B' . C')
    2. F = A. (A''+ B' + C')
    3. F = A . (B''.C') + A . (B + C')
    4. F = (A'' + B'') + A . B
    5. F = A'.B'+C'+A.(B'+C')
    6. F= A'. B+ D.(C+D') + A. B' . C' . D
    7. F = A. C'.D'+(A''.B'.C') + (A''.B')
    8. F = A.B'.C' + A'.B.C.D + A'.B.C'+A.B'C.D
    MY ANSWERS
    1. F=BA'.BC'
    2 F=A.AB.AC'
    3. F= AB + AC
    4. F=A.B
  2. joker_tony
    May 18, 2008
    step by step solution
    1. AB'+BB'+BC' (use complements laws B.B'=0)
    = AB'+BC'
    2. AA.AB'.AC' ( Use idempotency A.A= A)
    =A.AB'.AC'
    3. AB+AC+AB+AC(use idempotency A+A=A)
    =AB+AC
    4. (A.B)+A.B ( i think this one is wrong)
    =A.AB.AB.B
    =A.B
  3. Caveman
    Apr 15, 2008
    471
    This is incorrect. B AND B' = 0.
    This is incorrect as well.
    This is incorrect.
    Incorrect.
    I'll explain 1, and you should take it from there:
    First, get rid of the silly '' things A'' = A.
    1. F = B.(A . B' . C')
    Notice that they are all AND operations, so you can just drop the parenthesis.
    1. F = B. A''. B' . C'
    You can also swap the order (AND is commutative)
    1. F = A''. B. B' . C'
    B.B' = 0
    1. F = A''. 0 . C'
    Anything AND 0 = 0
    1. F = 0
  4. joker_tony
    May 18, 2008
    y do you have 1. F = B. A''. B' . C'
    A'' = A but you have put it back there after you have drop it
    you have A''
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    There is some helpful material on Boolean Algebra in the AAC ebook section. There are also some worked examples that may be worth reviewing.
    hgmjr
  6. sejan
    May 24, 2008
    7
    your no 1 is incorrect,it is 0.
    about no 2-it is A+A.B'+A.C'
    reduction-A(A"+B'+c')
    =AA"+AB'+AC'
    A+AB'+AC'
    no-3,it seems to be ok although my technique is different,i checked with K-map
    no-4-
    (A"+B")+A.B
    =A+B+A.B
    =A(1+B)+B
    =A+B (1+X=1)
    no 5-
    A'B'+C'+A(B'+c')
    =A'B'+C'+AB'+AC'
    =B'(A+A')+C'(1+A)
    =B'+C'
    I think you can carry on now-if confused use k-map to check
  7. Caveman
    Apr 15, 2008
    471
    Made a mistake there (cut-and-paste laziness), but the result is the same.
