Please help me circuit of input 100AC -240AC 50/60HZ to output 12VDC
mpcotuong
Joined Aug 26, 2010
170
Hi All,
I am planning to get input from AC of 100 to 240AC and out put of 12VDC.
Thanks,
Kevin
R!f@@
Joined Apr 2, 2009
9,918
100...240..............12...which is which.
U are not making any sense.
Is it that u want to get 12VDC from mains.?
t06afre
Joined May 11, 2009
5,934
If you plan to have a voltage range of 100 to 240 volt. I think you have to go for switch mode power supply. Probably primary switched also. Such power are not uncommon. I am holding one in my hand as we speak. However such power supply can be hard to build on your own. And the price for such do it your self project. Will be much higher than just purchasing some of the shelf unit. So unless you have to make one. Like in a school assignment. Get a standard one. As it is hard to beat mass production in this case. Parts may also hard to get in small volume
beenthere
Joined Apr 20, 2004
15,819
It is possible to get a transformer that accepts both 120 VAC and 240 VAC but a series/parallel arrangement of dual primary windings.
What is the current that must be supplied?
marshallf3
Joined Jul 26, 2010
2,358
Most PC supplies are capable of at least 10A at 12V even if they're fairly old.
If you search the 'net you'll find several links that show how to make a general purpose power supply out of an old PC power supply. New ones can be as cheap as $15 on sale or most small PC shops will gladly give you an old one.
They come two ways, one version has a switch to run on the 120V standard or the 240V standard, the other just self-selects which is the one you're looking for. They'll typically run just fine with an input as low as 90V
tom66
Joined May 9, 2009
2,595
Most cheaper PC power supplies use a voltage doubler when set on the 115 VAC range which boosts the voltage to 230 VAC. The problem with this circuit is that if you set it to the wrong voltage then Bang! goes the supply.
If you need 1A one solution might be to use a 7812 regulator and on the output of a 240VAC -> ~12VAC transformer, put a switch to enable the voltage doubler. This way, if you do set the wrong voltage, it'll be fine, but the regulator will probably shut down to protect itself (due to excessive power dissipation.)
Remember, a 12VAC transformer will have a peak output of 16.9 volts. Use a full wave rectifier and a big filter capacitor (around 2200µF should work), you'll have about 15.4 volts to play with.
marshallf3
Joined Jul 26, 2010
2,358
Thus the reason to find one that autoranges 120/240 as most seem to do nowadays - even several of the older ones would as well.
They use a PWM circuit on the input side that "slices" a portion of the incoming AC mains sine wave as needed.
tom66
Joined May 9, 2009
2,595
Active PFC. The advantage of this is reduced EMI and for some big electrical users (industrial users mostly) it reduces their bill. But the average user doesn't really benefit.
marshallf3
Joined Jul 26, 2010
2,358
So PFC truly benefits the power company not the user.
Having as close to 100% PFC really benefits everyone. The more efficiently you use the electricity the less strain on their systems, the less it costs them to generate X amount of electricity and the less ammo they have to charge the overall public more when the yearly corporation commission meetings come around.
Most home users are not monitored for power factor, it just isn't worth it. PFC becomes an issue when you're running quite a few large inductive loads although a large excess of capacitance can also upset it.
Tyically, when you're a large user of electricity, the power company's meter will keep an eye on your PFC and if it falls below a certain level you end up paying more per KWh used. Around here the penalty used to come into effect if you fell under 80%, as of last year they tried to get that up to 90% but the corporation commission only allowed them 85% as the breakover level.
I probably have around 300 HP worth of motors running at any one time and of those most are 24x7. I also have a ton of fluorescent and HID lighting which involve ballasts (also inductive). When we moved into the building our PF was hanging around 81%. There were a number of PFC correction caps around the building (the closer to the offending loads the better they work) but some were unhooked and others hooked up in areas where they didn't need to be anymore. Anyhow, through what limited calculations I could make along with tweaking the existing PFCs by removing some, moving some and adding a few others I've got us up to around 99% during the winter and 96% during the summer.
It's kind of a fine science:
http://en.wikipedia.org/wiki/Power_factor
It's also to my advantage. A motor that's properly corrected (or on a line that's fairly well corrected) is going to last longer for a number of reasons.
Audioguru
Joined Dec 20, 2007
11,248
I bought some surplus name-brand switched-mode power supplies made for old telephone-line modems. They are 5V at 2A but the label says the voltage is adjustable with a trimpot inside. I paid $1.50 each. I paid for the cord and the power supply was free.
Their output voltage is rock solid (a tiny amout of high frequency ripple) with an input of 85VAC to 240VAC.
Because they operate at a high frequency then their transformer is small and light-weight.
marshallf3
Joined Jul 26, 2010
2,358
Hi All,
Thanks,
Kevin
Of course if you really need to build it from scratch just get a 240 VAC to 24 VAC transformer then rectify and regulate the ouput down to 12V. If you run 120V into a 240V transformer primary you get roughly half the amount out of the secondary.
