Please help me building a filter...
Discussion in 'Homework Help' started by edsl, Sep 26, 2007.
  1. edsl
    Sep 26, 2007
    I’m studiying electronic and now we are learning to use and implement circuits in the laboratory. Now in the class teacher leave the following work:
    Design a low-pass and a high-pass filter using only resistors, capacitors and/or inductors and with this dates: Frequency cutoff (Fc) = 1KHz and Quality Factor (Q) = 0.5
    Ok, but the problem is that this design must be simulated in software like PSpice, I was trying to implement this, but I can’t. Can you help me?
    Thanks in advance!
  2. Kango
    Sep 22, 2007
    Why can´t you implement your circuit in Pspice?
    I also wondering what you mean with Q, I assume in your case that´s the amplitude. Is it under or upper frequency you want to study?
    Give us something of what you have done so far.
