Please help me answer a question from a test
Discussion in 'Homework Help' started by saruji, Jun 23, 2012.
  1. saruji
    Oct 18, 2011
    14
    http://i.imgur.com/qkv4A.jpg
    Find the Thevenin equivalent using the mesh current method.
    My teacher wrote it up but I was stuck,
    Thank you
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    Show what you've done so far.
  3. jegues
    Sep 13, 2010
    735
    43
    This should be fairly straightforward, 3 mesh loop equations and 3 unknown mesh currents.
    As WBahn mentions, in order for us to help you, you must first make an attempt at solving the problem yourself.
  4. saruji
    Oct 18, 2011
    14
    Right, I am very sorry for not posting a response earlier, I will post an answer up. I had posted this and then solved it and forgot about the post. I apologize.
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
    If you've solved it and don't need help anymore, then there's no pressing need to post your work or a solution. If it's easy for you to do, then by all means go ahead. You will probably get some useful feedback about alternative, perhaps easier, ways to have gone about it and, if nothing else, it makes the thread more useful for people that are searching for problems that they can try on their own.
