please help inductor question
Asad ahmed1
Joined Feb 10, 2016
68
My professor does not actually teach anything and he consider that we know every thing I took a look at the previous paper and i found this in it the inductor value is not given so how to find voltage across it the Formula v=Ldi/dt still be applicable to this
RBR1317
Joined Nov 13, 2010
714
What would be the best way to find the voltage across the inductor if you know the current through the resistor?
Can you find the value of L from the circuit time constant, τ? What is the energy stored in the inductor at t=0? Over time, all that energy will be dissipated in the resistor.
WBahn
Joined Mar 31, 2012
30,077
I'm getting a bit tired of hearing this excuse trotted out.
Why do you need to know the value of the inductor?
What is the relationship between the voltage across the resistor and the voltage across the inductor?
What do you need that isn't given in order to find the voltage across the resistor?
What do you need that isn't given in order to find the power dissipated in the resistor?
Asad ahmed1
Joined Feb 10, 2016
68
I need to know the value of inductor so i would put the formula v=Ldi/dt and find the value of v and for the power i can use p=i^2R
voltage across resistor is v=Ir and v across inductor is v=Ldi/dt
WBahn
Joined Mar 31, 2012
30,077
Again, you do NOT need to know the value of L to answer this question.
Answer the three questions (particularly the first one) that I asked.
RBR1317
Joined Nov 13, 2010
714
Why do you refer to the voltage across the resistor as \(I \times R\) implying that \(I\) is a constant when the current in the circuit is given as \(i(t)=20 e^{-1000t}\) or alternately as \(i(t)=20 e^{-t/\tau}\) where \(\tau = \frac{L}{R}\) ?
KL7AJ
Joined Nov 4, 2008
2,229
Dear Asad:
I'm sorry to say I've had a few teachers like that...I hope I never fall into that category. But yes, di/dt applies here. The voltage will actually be an exponential curve.
I also highly recommend BUILDING the circuit! You really get a lot more insight out of this when you have the actual hardware.
Keep up the good work...sooner or later you'll end up with a great teacher. I've had a few of them too!
eric
i assume that the circuit was connected to a source prior to having this circuit. you need to plug the time at which you want to find the voltage , you should that exponential decay equation to get the voltage at any time
Asad ahmed1
Joined Feb 10, 2016
68
@KL7AJ In the beginning of semester i asked him why we use the arrow into the node can we make all currents leave from node so i end up teaching him the KCl :/ now Iam taking lectures from the net and sites like this and reading books .thanks for the reply it made my day.
WBahn
Joined Mar 31, 2012
30,077
i can get the tau from this and i also have r so i can get the value of L
L=0.001x10 = 0.01H
You do NOT need to find the value of L. Forget it. It is not needed to answer these questions. Stop focusing on finding something that you do not need!
If I tell you that the voltage across the resistor is 3V, what is the voltage across the inductor?
Asad ahmed1
Joined Feb 10, 2016
68
In that case if the other terminal of resister is grounded then 0-V(L)=3volts V(L) = - 3 volts
WBahn
Joined Mar 31, 2012
30,077
Good, except that doesn't matter whether the "other terminal" is grounded or not. Notice that which terminal is being referred to in the first place is not specified, nor is the direction of the current. You get to pick.
So, for the given voltage, what is the voltage across the resistor as a function of time?
