Please help Identify Capacitor
Discussion in 'General Electronics Chat' started by IC_What, Jun 18, 2013.
  1. IC_What
    Dec 7, 2012
  2. IC_What
    Dec 7, 2012
    I tried to attach pictures
  3. absf
    Dec 29, 2010
    1,493
    374
    472k is 4.7nF or same as 0.0047uF
    152k is 1.5nF or same as 0.0015uF
    Allen
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    screen1988 likes this.
  5. IC_What
    Dec 7, 2012
    Allen
    How can I figure out what volts they are, I need to replace both the capacitors, When you replace caps you need the right volts and uF reading to replace right?
    Like if I had a 25v 330uf bad cap, I can replace it with a 25v 330uF new cap, and I can even go higher on the volts part of it right? but the 330uF needs to be the same, right?
    And Thanks so much
    Sorry for all the questions, new to the world of Capacitors..
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
