Please help i only got another day for my research.
Discussion in 'The Projects Forum' started by Ryka Thomas, Dec 16, 2015.
  1. Ryka Thomas
    Dec 16, 2015
    32
    Hi i have a school project to do i must make a powerbank and it must have a microcontroller , so i would like to ask if it is possible to/could use my microcontroller to act as voltage regulator and a charge regulator .
    Thanks in advance i will be pleased to answer any question :)
    RRITESH KAKKAR likes this.
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    Why did you wait till the last day? :)
  4. Ryka Thomas
    Dec 16, 2015
    32
    Seriously this question umm idont know
  5. Ryka Thomas
    Dec 16, 2015
    32
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
  7. ISB123
    May 21, 2014
    1,240
    531
    Microcontroller can be used to provide PWM for MOSFET which is used in SMPS,so yes it can be a part of power supply.Can it output voltage by itself?No!
    Ryka Thomas and RRITESH KAKKAR like this.
  8. spinnaker
    Oct 29, 2009
    5,065
    1,174
    Too much party not enough study.
    Ryka Thomas likes this.
  9. DickCappels
    Aug 21, 2008
    2,758
    667
    What kind of controller are you going to use?
  10. Picbuster
    Member
    Dec 2, 2013
    391
    53
    What voltage do you want to regulate?
    What charge curve to follow?
    Please send us your algorithm.
  11. Ryka Thomas
    Dec 16, 2015
    32
    MAY BE
  12. Colin55
    Member
    Aug 27, 2015
    204
    21
    That's easy. We can design a Power Bank for you, controlled by a microcontroller, design the PC board, get the board made, build up a prototype and have it tested with 23 hours of soak-testing, all within a single day.
    We will also have a voltage regulator and charge regulator incorporated in the project.
    Expected cost will be about $5.50
  13. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Man
    Do you ever work cheap! Doesn't even matter what kind of dollars they are. Who needs to outsource at those prices?
  14. Kermit2
    Feb 5, 2010
    3,847
    963
    The length of a day is based on a planets rotational velocity.
    SO...... the earth has stopped spinning.
    No applause. It was just simple logic. (Kermit takes a bow)
