please help! how does the circuit work
Discussion in 'General Electronics Chat' started by Harshit Agarwal, Jan 26, 2016.
  1. Harshit Agarwal
    Jan 26, 2016
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    What's the context of the question? Otherwise, "It works by applying 9 V between the top and bottom nodes," would be a valid response.
    Is this a homework problem?
    Harshit Agarwal likes this.
  3. crutschow
    Mar 14, 2008
    13,503
    3,376
    It's an astable multivibrator as described here.
  4. Harshit Agarwal
    Jan 26, 2016
    not a homework problem ,seen this somewhere and wanted to understand it
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    So I would recommend taking a look at the link that crutschow posted, if you haven't already, and see if that satisfies you. If not, then by all means come back and try to post a question or three that get at what part of the operation is vexing you. That should provide much better targeted help to address your confusion.
  6. hp1729
    Nov 23, 2015
    2,102
    233
    Assuming Q-left comes on first the collector moves toward +9 , discharging C-left, holding Q-right off. Eventually the capacitor drains and the resistor R-right pulls the base of Q-right to ground, turning it on. This discharges C-right, turning Q-left off. Eventually C-left discharges and resistor R-left turns Q-left back on which turns Q-right off ... all the magic is in the timing of the capacitors and the base resistors.
  7. cmartinez
    Jan 17, 2007
    3,698
    2,791
    To me, this circuit is a perfect candidate for simulation in LTspice that the OP could use as a playground, so that he could see for himself what would happen if he were to change or tweak the values of the components, and learn something along the process.
    absf likes this.
  8. hp1729
    Nov 23, 2015
    2,102
    233
    Emulate? Only ten parts. Build it.
  9. cmartinez
    Jan 17, 2007
    3,698
    2,791
    That too :)
  10. ronv
    Nov 12, 2008
    3,403
    1,477
    Easy for you to say. You have a scope. :D
    cmartinez likes this.
