thatoneguy
- Joined Feb 19, 2009
- 6,359
If you know what the output is supposed to be, look for a signal of the right frequency being generated by the ICs, then follow that signal to the link to the pads. At some point, the signal probably will vanish on that path. The path may go through ICs, Transistors, SCRs, etc. You'll need to look at the datasheets for the parts to determine what is input and what is output.
I use This site for datasheets, they have about everything and it is easy to navigate.
