Please help convert this ATtiny85 code to PIC
Discussion in 'Embedded Systems and Microcontrollers' started by Sal, Jan 16, 2013.
  1. Sal
    Jan 16, 2013
    Hello to all, can someone please help me to convert the following code from ATTiny85 to Pic 12f657?
    void setup() {
    // initialize the digital pin as an output. We are using Pin 2 on the Attiny85 microcontroller
    pinMode(2, OUTPUT);
    digitalWrite(2, HIGH);// blink LEDs once to signal power on
    delay(2000);
    digitalWrite(2, LOW);
    delay(7200000); // Wait 2 hours
    void loop() {
    digitalWrite(2, HIGH); // set the LED on
    delay(1000); // wait for a second
    digitalWrite(2, LOW); // set the LED off
    delay(600000); //Wait 10 minutes
  2. be80be
    Jul 5, 2008
    432
    57
    It not that hard give it a try.
    pinMode(2, OUTPUT); would be TRISO = 0x0;
    digitalWrite(2, HIGH); would be GPIO = 0x3;
    so setup would look like
    Code ( (Unknown Language)):
    1.
    2. void setup()
    3. {
    4.    CMCON = 0X7;  'turns off the comparator
    5.    ANSEL = 0x0;    ' turns off the ADC
    6.    TRISO = 0x0;    ' set's GPIO to outputs.
    7. }
    8.
    Now you add the config and the main code ok ? if you can't try to any way and I'll show you the rest and read this to http://ww1.microchip.com/downloads/en/devicedoc/41190c.pdf
    Oh and one more thing you sure you don't have a 12f675 theres no 12f657 ?
  3. Sal
    Jan 16, 2013
    Thanks! You were very helpfull!
    Now I get a different problem with error: "Argument is out of range"
    This is for:
    Delay_ms(7200000);
    It accepts only until 50000 for 4Mhz. I don't mind the timming but even i change it.. it's proportional with limits, and nothing really changes.
    Is there any solution to that? can I change limits somehow?
  4. MrChips
    Oct 2, 2009
    12,622
    3,451
    A 16-bit unsigned integer has a range of 0 to 65535.
  5. Sal
    Jan 16, 2013
    That means that i have to change 12f675 to something else?
  6. MrChips
    Oct 2, 2009
    12,622
    3,451
    Not really. You can put Delay_ms( ) into a loop to get the delay you wish or you can write your own delay function using unsigned long integers.
  7. be80be
    Jul 5, 2008
    432
    57
    If you would tell me what compiler your using I could help you better
    Here a little more code to look at.
    1.
    2. #include <xc.h>
    3. void setup()
    4. {
    5.    CMCON = 0X7;  //turns off the comparator
    6.    ANSEL = 0x0;  //turns off the ADC
    7.    TRISIO = 0x0; //set's GPIO to outputs
    8. }
    9.
    10. void time_H()
    11. {
    12.     unsigned long int x;
    13.     for(x=0;x<7200000;x++)  // the numbers will need to be based on clock
    14.     {
    15.     if ( x == 7200000 )
    16.     break;
    17.     }
    18. }
    19. void time_M()
    20. {
    21.     unsigned long int x;
    22.     for(x=0;x<100000;x++)  // the numbers will need to be based on clock
    23.     {
    24.     if ( x == 100000 )
    25.     break;
    26.     }
    27.
    28.
    29. }
    30. void main ()
    31. {
    32.  ; //user code here
    33. }
    34.
  8. Sal
    Jan 16, 2013
    Sure!, I use the:
    mikroC, mikroElektronika C compiler
    for Microchip PIC microcontrollers
    Version: 8.1.0.0
    and the Easypic3 board
    I drop the timing for battery saving reasons to 0.3MHz.
    The problems are the long delays,
    Delay_ms(6600000); should be 2 hours
    and
    Delay_ms(300000); should be 5 minutes
    I placed the setup above and this is the code i have so far without errors..
