Please help About this circuit! -Multiplier?
Discussion in 'General Electronics Chat' started by Zara Engineer, Apr 6, 2015.
  1. Zara Engineer
    Feb 6, 2015
    53
    Hello
    I found this circuit in an old book , I've drawn the circuit .
    With :
    - F : clock signal 100 Hz
    - M is a DC signal from -5 to +5
    The author said that the result is M*F.
    Please let me know
    thanks in advance
    Zara
  2. Zara Engineer
    Feb 6, 2015
    53
    sorry this is the image
  3. DickCappels
    Aug 21, 2008
    2,766
    667
    Please use a more description title next time.
    It is a balanced modulator provided that you switch the non-inverting input to ground with your carrier F. This causes the circuit to switch between inverting and not inverting the signal as a function of the state of F.
    Among other things, the swich can be a transistor if the base drive swings far enough below ground so that the collector-base junction does not become forward biased, with a MOSFET provided the capacitance is not to high, it can be a transmission gate (such 74HC4066) or a microcontroller out pin switched between being high impedance and ground if the signal is only a few hundred millivolts.
    R2 and R3 should be equal.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    I have used that circuit as a synchronous detector (also known as a synchronous demodulator). Typically, you set the gain of the opamp to alternate between +1 and -1 as a function of the "carrier", which is a square wave with a 50% duty cycle.
  5. Zara Engineer
    Feb 6, 2015
    53
    Hi guys
    thanks for help
    and sorry for mysterious title :)
    but until now, i didn't understand by equation how can we have an output equal to F*M ? or F*Vin
    I tried to put per example M = 0 ;
    F = V+ = V-
    that's mean that (0-F)/R2 = (F-Vout) /R3;
    R2 = R3 = R;
    => Vout = 2 * F; ??
    and about you it's F*M=F*0 = 0 ;
    Please let me know what's the equation of output ! and an example please .
    Thanks in advance.
    Zara
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    F is equal to + or -C, where C is a constant, like 1 or 1.345. It is not a true multiplier where C can be varied dynamically. (C cannot be a function of time)
  7. Zara Engineer
    Feb 6, 2015
    53
    Hello Mike
    Ok let's suppose the F clock is between -1 and +1 .
    how to conclude the equation of the output in function of M and F.
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
  9. joeyd999
    Jun 6, 2011
    2,756
    2,922
    And I use the analogue in the digital realm for digital synchronous detection.
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    Here is how to implement that function using an opamp. The switch shown is usually replaced with a FET. Note that the switch is closed when V(F)>0V; and is open when V(F)<=0V.
    Can you see how the switch reconfigures the opamp so that its gain goes from +1 to -1?
  11. Zara Engineer
    Feb 6, 2015
    53
    Hello Mike
    thank you very much for your patience and doing the simulation for me .
    it was very helpful.
