please gpr pcb deep please
Discussion in 'The Projects Forum' started by tawy, Nov 30, 2009.
  1. tawy
    Nov 22, 2009
    i need it so so match i must bult one pleas have enyone the pcb circut of a good and deep gpr metal detector
    thanks for you all
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    So, you think that you can just build a powerful ground penetrating radar with a PCB?
    Sorry, that's not how it works. You would need some expensive equipment, and know how to safely construct and operate high-powered equipment.
    Why do you need this, anyway?
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Are you sure you don't just want a simple metal detector?
    You'll note texting language isn't used much here.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    I'm glad you fellows translated for me. gpr had me fooled for a minute.
    n e way, chemelec hashadquiteanntrestinmetaldetectors: http://www3.telus.net/chemelec/Projects/Projects.htm
    It didn't use to have all the garbage. Maybe he has Hg poisoning. Scan about half way down to TDA0161 metal detector. Those chips are still available.
    John
  5. tawy
    Nov 22, 2009
    thanks gor you all
    we are a group of freinds we hope we can buld agpr becous in our country we have alot of hedin treasuers and metal detector dosnt work good we need gpr going to deep of 5-6 m
    forgive me i know my english is so bad
    thank tou one more time
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Your English is certainly better than I could hope to write in your language, even though I don't know where in the world you are, or what language you speak.
    Ground penetrating radar is a fairly recent development. It has been very helpful in efforts of locating and removal of land mines in several countries.
    However, equipment that is powerful enough to penetrate many meters below the ground, also has the potential to harm people that are operating it.
    It is against the policies of this Board to discuss topics that may cause harm in the way of bodily injury or property damage.
    If you do find somewhere to discuss this topic, be aware that to attempt to design and build such an item requires many years of training, normally at a college/university level, and experience.
    If you attempt to do so without prior training and experience, you will likely cause yourself and others in the immediate area to suffer injuries.
