Please explain this circuit of a coil-less fm transmitter
Discussion in 'The Projects Forum' started by Asmita Nayak, May 17, 2015.
  1. Asmita Nayak
    May 17, 2015
    9
    It would be of great help if anyone could explain in detail how each component in the circuit works.[​IMG]
  2. ScottWang
    Aug 23, 2012
    4,925
    777
    Are you the same person with DEBPARNA MAJUMDER?
    This forum only allowed one person one ID, if you are the same person, please decide which ID that you would like to reserved ?
    mattbullet likes this.
  3. Asmita Nayak
    May 17, 2015
    9
    No. Debparna Majumder and I are classmates working on the same project.
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    Ok, thank you.
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I would NEVER build the given transmitter as it will transmit EVERY 10.7 MHz.
    Bertus
  6. ScottWang
    Aug 23, 2012
    4,925
    777
    10.7Mhz, that is a little strange, I was played 88~108Mhz in Fm and remote control with 27Mhz.
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    You will hear ALL harmonics created by the 10.7 Mhz filter used in the oscillator section.
    The 9th and 10th harmonic can be heard in the FM band at 96.3 and 107 Mhz.
    BUT the 8th harmonic will fall below the FM band 85.6 Mhz, wich could be in the aircraft band.
    Bertus
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Not all circuits you find on the internet are good ones. This one is illegal, a square wave should never be used to broadcast.
    The ceramic resonator is filling the role of inductor in this circuit.
  9. Asmita Nayak
    May 17, 2015
    9
    There is a frequency multiplier after the oscilltor. The transmitted frequency will be 96.3 Mhz.
  10. ScottWang
    Aug 23, 2012
    4,925
    777
    So you have to divided by 9 for the audio, does the audio still can keep the normal sound ?
  11. Asmita Nayak
    May 17, 2015
    9
    There's some noise but the audio can be heard.
  12. alfacliff
    Dec 13, 2013
    2,449
    428
    a freqiuency multiplyer does not devide the modulating frequency, it multiplys it. probably not enough since there is noise too. and using a varicap to fm modulate a 10.7 ceramic filter isnt going to fm the signal much.
  13. ScottWang
    Aug 23, 2012
    4,925
    777
    Normally the FM transmitter modulate the frequency 88~108Mhz with audio sound that it assuming the frequency as 300Hz to 5Khz used a small microphone.
    If you multiple the transmitter's frequency 9 time from 10.7Mhz to 96.3Mhz, then the audio frequency will be also multiple 9 times from 2.7Khz to 45 Khz, so that's why I said that you need to divided by 9 to back to the original frequency of audio sound, is this used digital or linear to divide the frequency that I'm interested in this.
  14. Asmita Nayak
    May 17, 2015
    9
    Can anyone explain how the CMOS inverter N2 works as an oscillator in this circuit?
  15. DickCappels
    Aug 21, 2008
    2,758
    667
  16. Asmita Nayak
    May 17, 2015
    9
    Its a project I'm working on.
  17. Asmita Nayak
    May 17, 2015
    9
  18. Alec_t
    Sep 17, 2013
    5,968
    1,135
    There is no frequency multiplier. The 4069 gates merely act as buffers and current boosters for the 10.7 MHz square-wave. A square-wave output in theory contains an infinite number of odd harmonics of the fundamental frequency (the ninth harmonic being 96.3 MHz), so you will splatter RF interference across a wide band. See Bertus' post #7.
    Not much. Positive feedback from the output to the input of an amplifier turns it into an oscillator.
  19. JWHassler
    Member
    Sep 25, 2013
    204
    34
    The difference is that "oscillators don't and amplifiers do."
  20. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    Don't think so. This is FM, so the deviation and modulation bandwidth will increase by 9 times, but the rate of deviation will be the same. The carrier will transition from one instantaneous frequency to the next at the original audio rate.
    ak
