Excellent point!Please note the slew rate, which is measured in Volts / second (or microsecond) is not the same as the rise time, which is measured in seconds (or microseconds)
They may be measured by different parameters but they are two sides of the same coin. Of course rise time does not have an amplitude component and slew rate does.Please note the slew rate, which is measured in Volts / second (or microsecond) is not the same as the rise time, which is measured in seconds (or microseconds)
It only increase losses for power switches such as used in switching power supplies. For digital logic type switches, where the primary loss is the charging and discharging of the stray capacitances, the rise or fall time has little effect on power loss.A good thin to remember is that ANY waveform can be expressed as a series of sine waves (Fourier series) and the faster the waveform rises, the higher the frequency content. A vertical edge has theoretically energy out to infinity. The higher the frequency content, the more easily EMI radiates. The down side is that slowing the rising or falling edges increases switching losses.
True, I spent so many years designing power converters that I forget about low power junk. A guy I worked with interviewed a lady who had spent years working for the power company (dealing with HV transformers) and he asked her an interview question:It only increase losses for power switches such as used in switching power supplies. For digital logic type switches, where the primary loss is the charging and discharging of the stray capacitances, the rise or fall time has little effect on power loss.
by Jake Hertz
by Aaron Carman
by Aaron Carman
by Aaron Carman
