Please explain FET and circuit gains I'm seeing
Discussion in 'The Projects Forum' started by Darkstar, Jun 28, 2011.
  1. Darkstar
    Thread Starter Active Member
    Sep 3, 2010
    104
    I've been designing a simple dual FET Wheatstone bridge using the website "www.falstad.com/" which allows one to draw a circuit very easily and it shows how it runs and does all the calculations. It's very simple to use.
    I've attached a pic of a typical circuit ...
    The transistors used in the simulation are supposed to be MPF102 n-JFETs, with Vp= -8V, and a 20mA limit.
    By playing with bias resistor values, I've gotten some unusual results.
    The attached table of my data shows a range of values for FET gain, gm, and the signal amplitudes I got for each circuit I tried.
    In the very high signal amplitude circuits, the resistor settings are extremely touchy. Small changes can send the amplitude from the mV range down to the uV range.
    My questions are:
    1. Are these high signal gains realistic?
    2. Why should circuits with low FET gain, gm, have high signal amplitudes and vice-versa?
    3. Why don't the circuits with the highest gm have the highest signal amplitudes?
    4. Looking at the chart, which values should I strive for? High gm but lower signal amplitude (assuming these amplitudes are actually possible)? Or, low amplitude, with high gm value?
    Or, should I look at some combination of the other FET parameters?
