Attached is a schematic for an adjustable regulator using an LM317T. I would be grateful for comments and corrections before I lay out the PCB.
Thanks.
Thanks.
+1i don't see anything wrong.
I don't know what it does to response time, but this circuit is recommended by TI/National. See fig. 3 in the datasheet.I would get rid of D6 and C3, you want the fastest response you can get out of this chip, and they would only slow things down regulation wise.
The adjustment terminal can be bypassed to ground on the
LM117 to improve ripple rejection. This bypass capacitor prevents
ripple from being amplified as the output voltage is
increased. With a 10 μF bypass capacitor 80dB ripple rejection
is obtainable at any output level. Increases over 10 μF do
not appreciably improve the ripple rejection at frequencies
above 120Hz. If the bypass capacitor is used, it is sometimes
necessary to include protection diodes to prevent the capacitor
from discharging through internal low current paths and
damaging the device.
by Duane Benson
by Robert Keim
by Jake Hertz
by Jake Hertz
