Please can anyone find for me the Gain?
Discussion in 'Analog & Mixed-Signal Design' started by student111111, Jul 26, 2016.
  1. student111111
    Jul 26, 2016
  2. BobTPH
    Jun 5, 2013
    807
    121
    Please put the schematic in you post. I don't click on random links that might infect my computer.
    Bob
  3. student111111
    Jul 26, 2016
    Greetings
    I do understand that u might be suspicious and worried about your pc there is plenty of trojans around so for that how do you recommend me to upload the figure you would like it on Dropbox or via email or whatsapp Image or any other method kindly note that is is an urgent issue and I would like to find the gain of this circuit
    I attached the graph here if this is not enough or not a trustworhty issue let me know!
    Thank you in advance
    Ali
  4. benta
    Member
    Dec 7, 2015
    101
    24
    I'd say a Kirchhoff node analysis is the way to go here.
    Apart from that, I'm not doing your homework for you.
  5. m zaid
    Member
    Jan 9, 2016
    46
    5
    Sarcastic is rude. Don't talk like that to someone you just met and asking for help.
  6. joeyd999
    Jun 6, 2011
    2,759
    2,942
    You didn't ask for help. You asked someone to do the work for you.
  7. DickCappels
    Aug 21, 2008
    2,780
    675
    Please upload your schematic using the "Upload" button.
    Who would ever design a circuit like that....?
  8. Bordodynov
    May 20, 2015
    673
    194
    See
  9. DickCappels
    Aug 21, 2008
    2,780
    675
    It looks like you have the correct, if we ignore mention of R4.
  10. hp1729
    Nov 23, 2015
    2,105
    235
    But that is not the original circuit. His non-inverting input is the output. Wouldn't it be the same voltage as the inverting input. Gain of 1.
  11. Bordodynov
    May 20, 2015
    673
    194
    I am sorry/
    See new file
  12. hp1729
    Nov 23, 2015
    2,105
    235
  13. hp1729
    Nov 23, 2015
    2,105
    235
    Strictly a classroom question without practical application?
  14. Bordodynov
    May 20, 2015
    673
    194
    Apparently you do not understand.
    Gain = Vout / Vin = V (out) / 1V = x.
    The question you have put wrong. Maximum transmission coefficients on the pseudo-resonance is 1 = 0db (at a frequency of 159Hz =1/(10k * 0.1u) / 2Pi. On the other frequencies ratio is less than 1. Carefully watch my pictures. I showed what is (analytically) transfer coefficient. I used complex number.
  15. hp1729
    Nov 23, 2015
    2,105
    235
    Certainly something for me to learn here. Math aside .. the output is connected to the non-inverting input. Shouldn't that follow the inverting input for a no gain condition? Frequency characteristics of the op amp not considered in my thoughts, of course.
    Given your formula, if we double the values of R3 and R4 we get a gain of -2. ??? It seems the output of the op amp would follow your math but the output of the circuit is not the output of the op amp.
    (edited to add ...)
    Or will the inverting input be at virtual ground and the output following that. Not no gain. no output???
    Or a current output like a Howland Current Pump?
  16. Bordodynov
    May 20, 2015
    673
    194
    LTspice ==> Mag(Gain)=1 Phase=-180 ==> Gain=-1 (freq=159Hz)
    A formula I recheck. It seems I made a mistake somewhere.
