pleas help me :( -Digital Clock in Multisim
Discussion in 'Homework Help' started by tamialjamily, Dec 8, 2015.
  1. tamialjamily
    Dec 8, 2015
    9
    my teacher asked me for make a digital clock using multisim by jk flip flop counter and dcd_hex
  2. crutschow
    Mar 14, 2008
    13,505
    3,379
    That's a bad, non-descriptive thread title.
    Please be more specific in future posts.
    So what have you done so far?
    This is a Homework Help forum not a Homework Do.
  3. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    UR such a party pooper...........................
  4. crutschow
    Mar 14, 2008
    13,505
    3,379
    I'm an expert at that, rather like the Cooler in a Las Vegas casino. :cool:
    Hypatia's Protege likes this.
  5. WBahn
    Mar 31, 2012
    18,088
    4,917
    So.... what have you done so far?
    What kind of digital clock?
    What features does it need to have?
    What is dcd_hex?
  6. tamialjamily
    Dec 8, 2015
    9
    -_- u wanna to help me or not
  7. tamialjamily
    Dec 8, 2015
    9
  8. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    You need to help us first. We're not here to do your homework for you. You need to show us ALL of your work and attempts first. Only the will we point out where you went wrong and point you in the right direction. We will not solve anything for you.
    absf likes this.
  9. WBahn
    Mar 31, 2012
    18,088
    4,917
    A schematic is definitely one step in the right direction, but it does nothing to help us understand what the problem is asking for or whether you are doing what is asked of you. Your schematic shows two four-bit circuits each driving a single digit display with no apparent interaction between them. How does this constitute a "clock"? Maybe it does, within the context of this assignment, but we have no idea what that context is. As a result, we have to guess, based on the circuit, what it is supposed to do. But if we do that then the only conclusion we can come to is that it is supposed to do whatever it is that is actually does, making it impossible to know whether there is a problem with it.
    We need you to describe the specific project specifications and then walk us through YOUR design. Then we are in a position to spot areas where you are going astray.
  10. tamialjamily
    Dec 8, 2015
    9
  11. WBahn
    Mar 31, 2012
    18,088
    4,917
    Repeating yourself by attaching the same file again does not move the discussion forward.
    spinnaker, absf and DerStrom8 like this.
  12. ian field
    Oct 27, 2012
    4,456
    792
    Last MSI digital clock circuit I saw used a lot of 7490 BCD decade counters and a few of the 16 bit type.
    The 7490 internal structure is made up with interconnected divide 2 flip flops that reset themselves at the required count. The 16 bit counters are nothing more than cascaded divide 2 flip flops.
    AFAIK: the 7490 is obsolete and had been replaced by a new device with 2 BCD counters in the same package (possibly a 74290) - the internals of either can be found online.
    tamialjamily likes this.
  13. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    That schematic is pretty much useless. Doesn't help us at all. Try again.
  14. absf
    Dec 29, 2010
    1,493
    374
    May be this would get you started... 3 JK Flip flops that would count to six.
    Look for /10 and /12 circuits that use JKFF on the net.
    Allen
  15. JoeJester
    Apr 26, 2005
    3,402
    1,227
    ok ... is it 12 hour format or 24 hour format?
    Can you draw a block diagram of what you need to do?
  16. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  17. tamialjamily
    Dec 8, 2015
    9
  18. tamialjamily
    Dec 8, 2015
    9
    no just one clock by jk f/f
  19. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    On the following page of the EDUCYPEDIA you will find links about couters and registers:
    Counters & registers
    Bertus
  20. tamialjamily
    Dec 8, 2015
    9
    thanks ^_^
