plc
Discussion in 'General Electronics Chat' started by jogpals, Dec 4, 2007.
  1. jogpals
    Dec 4, 2007
    8
    in want to know how plc communication with programmer and its method plc siemens simatic300 and progerammer is pg 720 siemens
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The most general answer is that it uses one or more industry standard serial interfaces. The data to be transferred is broken up into blocks of data called packets. The packets are made up of individual characters or bytes, typically 8 bits in length. The eight bit bytes may go over the wire with either the most significant byte first or the least significant byte first. The crucial thing here is that both ends must agree on the same set of rules, which is often called a protocol. It means the same thing as in diplomacy.
