PLC
Ahlawygamd
Joined Apr 14, 2006
I'm Egyptian
I will participate in Robocon Egypt 2006 next July
I want to learn programming of PLC and how can I use PLC
Can you help me
Papabravo
Joined Feb 24, 2006
21,228
Originally posted by Ahlawygamd@Apr 14 2006, 07:24 PM
I'm Egyptian
Can you help me
[post=16184]Quoted post[/post]​
I would start by learning how to write and understand ladder logic. I think you can google this term. Many PLC's are still programmed according the this methodology because plant electricians (at least in the US) are familiar and comfortable with this method.
The next step would be contact PLC vendors or go to their websites. Here you are looking for demo software that will allow you to program one of their products. I don't know if the following companies have a presence in Egypt, but you should be able to establish that with minimal effort.
Major PLC Vendors
Allen-Bradley
Omron
Siemmens
Eaton/Cutler-Hammer
Square-D
Ahlawygamd
Joined Apr 14, 2006
Dear Papabravo
Thank you , your help is very useful for me
I think that Siemens has a branch in Cairo , I will contact them
but i have a problem on treating the hardware of the PLC
Papabravo
Joined Feb 24, 2006
21,228
Originally posted by Ahlawygamd@Apr 15 2006, 07:32 PM
Dear Papabravo
[post=16211]Quoted post[/post]​
Each PLC is different but the basic idea is to treat each "rung" of a ladder as a single boolean equation. In a real ladder logic implementation with relays all the equations are "solved" in parallel in continuous time. In a PLC the processing algoithm is executed repeatedly at high speed.
The Basic PLC Algorithm
Rich (BB code):
DO
 1. Sample and gather the inputs into an "input image table"
 2. Solve each of the ladder rungs to create an "output image table"
 3. Update the real outputs from the "output image table"
WHILE(1)
The basic hardware device in ladder logic is the relay. What are the properties of a relay? Well it has a coil, like the one in a solenoid. The coil is energized if it has current flowing through it. The current can be either AC or DC. If there is no current flowing in the coil it is de-energized. A relay will have one or more contacts associated with it's coil. These contacts are called NO(Normally Open) and NC(Normally Closed). These terms describe the state of the contacts when the coil is de-energized. When the coil is energized an NO contact will close, and an NC contact will open.
To implement a boolean function with contacts and mechanical switches you connect them in series to perform an "AND" function and you connect them in parallel to perform an "OR" function.
In the PLC there is often a graphical interface that will allow you to write your control progam in terms of "relay ladder logic"
Hope this helps.
Gadget
Joined Jan 10, 2006
614
Many PLC manufacturers also offer free programming software with instructions, demo's and built in simulation (the Zelio series I have used certainly do).
Others may offer a Starter pack with PLC/Software/demo's/Programming cable/and comprehensive instructions.
Wont hurt to ask
engs1982
Joined Feb 7, 2009
i am also learn the pl myself only, so u choose siemens logo plc it very easy, also the siemns web pronide the demo s/w i.e soft comfort
try it , do it
