MaxHeadRoom
- Joined Jul 18, 2013
- 28,686
Looks like you just need a typical stop/start rung with the start button ANDed with the n.c. stop P.B. and a internal contact across the start P.B. this contact would be the internal coil output at the end of the string.
A contact with the same output address would go in each operation string and temporarily halt it.
An E-stop button would cancel all actuators and cause a retract.
It is hard to give a definitive answer without the mechanical details of the system.
A logic control is usually designed based on actual full mechanical details, including hydraulic/pneumatic details, if any .
Max.
Max.
