PLC logger
Discussion in 'Programmer's Corner' started by roro36, Mar 23, 2011.
  1. roro36
    Sep 7, 2010
    52
    I'm using a dvp32es2 plc to monitor machine usage in our factory. The PLC is reading a current trasformer to determine when the machine is switched on. However, I would like to be able to log this info as well. At least on an hourly or dialy basis. I'm not sure if there is a way to automatically log data with the PLC or if I hve to sav e the values to an icreading array of registers?
  2. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    you could capture it in a circulat buffer, however, I'm sure you'll want to gain access to that info. Do you have any HMIs? Historians are a common feature HMI software. Optionally you could pull it out over your comm port with Qlink or similar and log it in a database.
  3. roro36
    Sep 7, 2010
    52
    Yes, i'm using an HMI to display the data? So would I just link the HMI historian to the data register that keeps changing and the rest will follow?
  4. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    should be that easy.
    roro36 likes this.
